your 94 model is equipped with a brake pressure switch. it is located on the brake master cylinder. when you unplug it check for brake fluid inside the switch and on the plug itself. if so the switch is defective. also check the plug to see if it is the original plug or if it part of an extension. the switch is under recall from ford and when they install the new switch they install a extension harness.
STAK, I removed the harness on the Master Cyl. It has a non serviceable fuse in line. I ohm'ed it out and all is good. Also the switch on the cyl itself is good. I am not going to go into the steering column. Thanks again.
