Has anyone had issues with the blend door on the AC system. I will have it on AC or MAX AC. I will have it on the setting to be point out of the dash at me. It occasionally will switch to the defrost windshield setting. I can hear the blend door moving and changing from chest level to the windshield.
Low vacum. Very common. The usual fail point is the 4WD vacum system because it uses the same vacum source. What failed on mine was the ESOF switch, this is what actuated the front hubs, they are vacum operated when in the auto position.
Can someone please explain to me the auto position? Is this on the hubs, or like an auto position on the 4WD selector switch on the dash? Mine only has 2WD, 4hi, 4low?
I am assuming you are talking about the hub correct?
Thanks guys- got it fixed. The rubber was so old I was able to be grind into rubber eraser shaving material with my fingers.. Put some new rubber lines on and its good to go.
oh boy, can someone point a nail bender in the right direction as to where these vac lines are and how to fix?
thanks
Your ESOF vacuum actuator is located on the passenger's side inside fender wall, just back from the battery. It has an electrical connector and a few vacuum lines on it, this is the valve that allows vacuum to the front hubs to lock and unlock them when the dash switch is used.
Most common place for the vacuum lines to fail is between the frame and the axle in the wheel wells, where they are most exposed to the elements. Check those cheap rubber hoses for any signs of cracking, splitting or deterioration, if they are shot your stock hubs will not lock.
