Fuel pump is toast....and discontinued?
The upper pump is original Carter. The lower is the new Napa.
The van had been having these weird issues with sporadic fuel delivery. I have the mechanical pump and it finally quit and left me stranded in the middle of town. I walked to Napa and picked up the pump but after removing the old one and comparing the two they were totally different. I went back to Napa and they said that's the one for the van so I thought maybe it was updated or something. I went to put it on and its totally not going to fit because the oil filter interferes with not only the installation but would interfere with the fuel lines as well. Ive checked the net for hours and it seems like all these mechanical pumps for the 75 to 78 Econolines are discontinued. Anyone here ran into this on the trucks or is the van unique to this? Whats the best setup if I need to convert to an electrical pump? Thanks for any advice.
The following users liked this post:
Hmm ... looking on RockAuto, a '78 F350 with 460 shows what looks like the lower pump in your picture, while a '78 E350 with 460 has only electric pumps listed to be used as replacements for the mechanical pump. Weird. You may be right about that upper style being discontinued.
http://www.rockauto.com/catalog/more...nid=486&jpid=0
More Information for AIRTEX E84070N
Either that or the top one is bent and that's why its not working correctly!
Ya its the top mount and it needs that to avoid the oil filter. The lower one wont clear the filter and even if it did the outlets would be about a half inch from the filter. I just bought a precision universal electric pump. I talked to a Tech from Airtex and he confirmed that that pump is discontinued by all manufacturers. Kinda crappy but ok whatever. Thanks for looking out guys.
Not that I know the answer, but its probably location and layout. The van motors (and RVs) were crammed into tiny areas with changes to layout of some items and shapes of others. That would be my guess as to why its different.
can't help on the issue of the different pumps, but at the risk of telling you something you already know, the ethanol in the regular gas these days will destroy your pump. I found this out the hard way and now just burn the highest grade fuel. wouldn't want you to install a new pump and have the same problem.
