Electrical Problem-Need Help
Old 02-22-2002, 12:52 PM
tmcalavy's Avatar
tmcalavy
tmcalavy is offline
Old 03-05-2002, 07:24 AM
ACEMAN's Avatar
ACEMAN
ACEMAN is offline
Post Electrical Problem-Need Help
I bought a new 1988 F150 and the inspection failed because the hazard lights failed to operate, but when I push on the brake with the hazard switch on lights operate. Fuses were checked and good. Grounds were also checked and are fine. Dilemma, Please help us.
Old 03-05-2002, 07:55 AM
kioolt's Avatar
kioolt
kioolt is offline
Check the HAZARD flasher. It's a different one then what makes your turn signals flash. Don't know where it's at.
Old 03-05-2002, 07:58 AM
michaelskerrett's Avatar
michaelskerrett
michaelskerrett is offline
While new to you, it's not exactly a new truck. I'd say it is just getting broken-in. Check the emergency flasher. It is separate from the turn signal flasher and if it fails the lights will still work for running and brakes. Also be sure both filiments in the front and real lamps are not blown. The flasher is about $2.50 at all auto parts stores.
Old 03-05-2002, 12:58 PM
mickelsons's Avatar
mickelsons
mickelsons is offline
I agree completly it is most likely the flasher.
Scott
