Toyota power steering upgrade and 4x4
Should be strong enough...Ive ran big tire 80-83 Toyotas (i believe this is the common year for aftermarket steering boxes) through the mud for years without havng a problem with the box. On a seperate note....I bought the Classic Performance Parts kit for my 59 4x4...great kit, but beware!!! you have to use your factory steering shaft with their rag joint, the factory 4wd trucks have a larger diameter steering shaft that will not work!! i found this out after i butchered my shaft up. they wont garauntee their kit to hold up on a 4wd but i dont forsee any problems...plan on runnin it with a swapped in dana 60
big78f150
11-28-2010 10:57 AM
fishin1976
01-14-2004 12:18 AM
