Ignition Help
Ignition Help
I have a 1976 f-250 with the duraspark ignition setup. I replaced my valve head gaskets and the fuse for the dome lamp over the weekend and now i cant get it to start!
I checked the ignition module and it checked out ok. I checked all of the coil wiring and distributor position sensor wiring and all checked with the proper continuity and voltage. Checked the coil and resistance checked out ok as well. I have only had thentruck for a few months. The positive side of the coil has never been connected to anything and it has run fine. Maybe is is because the prior owner put on a 12 volt coil....Anyways
Here is the only thing i could find...when i check the voltage to the coil when key is in the run position it only read 1.0 volts. When i unplug the wires to the distributor then i get 12 volts at the coil. No spark from the distributor or coil...any ideas?
TomH5898
05-16-2007 06:39 PM
BobcatGuy
02-19-2007 10:41 AM
broke1987f150
06-08-2004 05:59 PM
wndrhmr
05-04-2004 09:07 PM
heybrent
08-09-2002 09:57 AM
