Filled up with Diesel and about a hour later the truck is knocking and idling rough
MMO is great stuff for its intended purpose. This ain't it.
Pull a fuel sample from the tank with a siphon hose, maybe a quart or so if you are concerned about contamination. Some things to look for are strong gasoline odor for example. Take a small amount and (safely!) try to light it. Straight diesel will not ignite.
Also save your receipt. It it's a station fault they should cover it.
Like John said run out some into a glass jar and let it set overnight.
You can also give it a sniff but I don't know if gas would smell or not.
Also I agree if you had 3/4 tank of gas in it you most likely would
not of gotten out of the driveway of the station before it started
to act up. If the sample looks good then pull the lower filter and
see what it looks like.
Post back and let us know what you find.
Sean
6.0L Tech Folder
NEVER USE THE WATER REMOVER STUFF.
The filter has an element to separate the water and that stuff
will let the water pass and into the injectors and then your going
to be really hurting.
Sean
6.0L Tech Folder
I drained about a gallon or so out of the water separator, its smells like diesel fuel and will not light. no codes...will a high volume of water in the fuel just make the truck run like poo, with out throwing any codes?
i got a bad tank with lots of water when I was driving back from Kodiak.......
stop, drain, drive, stop, drain--- repeat
ended up with a mechanic doing a fuil system flush, and tank cleaning
the fuel station refused to do any remembursement --- mainly I believe because I live 500 miles away in North Pole!!
good luck, and let us know what you find out
Chris
Chris
