Need some roof rebuilding and rust advice.
I started stripping my gutters and paint to get at the rust on my 78. I was planning on using ospho or some type of rust converter then bed line it until I saw the extent of the damage. Now Im back to square one. It looks like someone used a bunch of bondo on the roof and thats cracking and rusting underneath. What do you guys recommend for these roof angles with the holes and all the bondo?
Cracked bondo
Holes on the top after grinding the bondo away.
Cracked bondo
Well I see! oh my.. You are going to have to replace some metal.....
if mine is that bad maybe Ill have to think outside the box!
http://thumbsnap.com/sc/Qg97Nrs7.jpg
or
https://www.google.com/search?q=cut+...KSmPpzx_cWM%3A
or
Rust is rust whether on a van or a car or truck.The 100% proper, long lived way is probably change the entire roof panel taken from a donor rig.If this is a van you are working on ,that option is not very practical. So a fella' needs to cut out the section of rusted area,check to see if you got it all(which you won't first time),cut out a bit more here a little more there until the rusted metal is cutaway. Where it joins in the gutter area is another issue as that will be a pain to cut out & replace. By replacing I mean welding in new metal where ever rust was cut away. Pop riveting and fiberglassing or Bondo will give you a a repair that will last for a while,it depends on the quality of the prep work. Also plastic fillers (Bondos) will last the life of a vehicle if applied properly. You have a tough spot there. Good luck. Gary
I have a couple of suggestions. The first and probably the best option is to find another van roof. I think if you get into the gutter areas more, you will find that the internal structure is rusted also. If it is a window van, I would try to find one exactly the same, cut down the door pillars and weld on a whole new roof section.
The other option is to find a van and cut out bad sections and put in new metal. The only place you will find the curves and inner structure is from another van. The good news is, the vans didn't change body styles till the early 90's.
Do an search in this section, there are several really good posts on roof repair of the trucks, including pictures of the many parts that intersect there at the rain gutter. This will give you an idea of whats in there and some ideas of how to proceed.
Unless you have some sentimental attachment to this van I would think long and hard about undertaking this project .. Here's just an example of what's out there to be had ..
I'm gonna have to do the same with my '70 F100 and break out the recip saw.
My attachment is that this is a 78 Quadravan with almost everything upgraded or replaced including a new trans with a shift kit, new transfer case, new front bearings, valve job, new performer intake, 650 thunder series carb, new radiator and hoses, new water pump, new starter, new alternator, new belts, new muffler and pipe, new distributor, brand new
BFG 33" AT's, new Redhead steering gear, all new rear brake components, new coil........the list goes on and on.
The rig runs awesome now and the only rust on the whole damn thing is on the roof. Ive always wanted a 4x4 van and you rarely see them down here. Ive been looking into van toppers and need to find out how much meat you need for them to be mounted solidly and if they cover the gutters. If I can get in there with some Ospho or Por 15 and stop the cancer then seal it up with a cap on the top that might be a good fix.
I spent hours researching last night and unfortunately this was one of the worst cases of roof rot Ive found on a van so far. Im really depressed about this but crying in my beer isn't going to help the situation.
I think it would be easier to sheet metal over windows you didn't want then patch the roof ..
It says it's a 1990 but I think that's a misprint $600 in North portland .. https://portland.craigslist.org/mlt/cto/5129370066.html
As I am not aware of your wallet or capabilities I have suggested a couple of options to repair in my previous response. The absolute most long lived repair is what a couple of us have mentioned and that is a donor roof. And yes as 4x4slik says ,a man would cut down a bit into the post. There are proper ways of cutting and rewelding when you do a "clip" but it is a good repair but pretty involved for someone that is not cut and weld inclined. I have "clipped" totaled vehicles by using 2 or even 3 donor vehicles a zillion times over the years and by using proper techniques they are at times stronger than the factory where you join them together. Takes time and a bit of common sense but ,again, a good permanent repair. Gary
