1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
i believe its the trans that howls in 4wd high
Old 07-21-2015, 06:34 AM
Tom's Avatar
Tom
Tom is online now
Originally Posted by SuperDutyScaler
ill go do what you suggested Tom and post back
So how did that go?
Old 07-21-2015, 04:25 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
I'm hooking up my vacuum gauge and curl pressure gauge right now, give me five minutes. Lol
Old 07-21-2015, 08:37 PM
SuperDutyScaler
ok as soon as i held the brake and applied the skinny pedal in 2wd the squeal/howl is back. Im 100% positive its inside the trans, heres the video. you can clearly hear it
View My Video
Old 07-21-2015, 08:39 PM
SuperDutyScaler
it does it in reverse/all forward gears in 2wd/4wd high BUT not in 2low or 4low in any gear?
Old 07-22-2015, 10:26 PM
TexasRebel's Avatar
TexasRebel
TexasRebel is offline
you have a 2wd low?
Old 07-24-2015, 12:45 PM
SuperDutyScaler
Yes, since I threw the Auto/lock hubs away after the Second set was replaced by the dealer under warranty I bought a set of warn premium hubs so I can turn the switch to four low and leave the hubs in free mode and that gives me two low
So anybody have any advice on the Howling in the video I posted and what it is and what I can do to fix it
Old 07-24-2015, 05:10 PM
TexasRebel's Avatar
TexasRebel
Could be clutches slipping. Goes away in low because the torque requirement is reduced.
how many miles on the transmission?
Old 07-24-2015, 08:45 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
It's easy to tell if a clutch is slipping. If it is the trans fluid will be brown or black.
Old 07-24-2015, 09:37 PM
SuperDutyScaler
Almost 135k and I've been having a lot of issues with the transmission over the past couple of years
Old 07-24-2015, 09:38 PM
SuperDutyScaler
And I'll check the fluid in the trans tomorrow
Old 07-25-2015, 04:46 PM
SuperDutyScaler
drained some fluid from the transmission and there was nothing in the bottom. Also checked the tcase and (it might have been hot) but almost half a quart id say came out of the fill plug?
Old 07-25-2015, 05:38 PM
Tom's Avatar
Tom
Tom is online now
Didn't answer the question. Was it brown? Red? Green?
  #28
Old 07-25-2015, 08:11 PM
SuperDutyScaler
sorry red coming out, looked clean. my pan is black so cant tell after that
  #29
Old 07-25-2015, 08:17 PM
Bigpipes 35's Avatar
Bigpipes 35
Bigpipes 35 is offline
Your seal is leaking between the trans and transfer case which is overfilling the T-case. I had the same thing happen on my F-150. I just checked the T-case fluid once a month and drained out the overflow. According to the trans shop I use it is a fairly common problem and seams to happen when the trans gets to warm. On a side note make sure to watch the Trans fluid so it doesn't get to low. My F-150 made a high pitched squeal when I was driving if the T-case was overfilled....
  #30
Old 07-25-2015, 11:11 PM
SuperDutyScaler
I just replaced that seal last September when I had the trans out to get the front pump seals replaced so it didn't leak into the tcase... man whatever I do to stop a problem is giving me the problem I tried to stop.
Quick Reply: i believe its the trans that howls in 4wd high
