Help, coolant leak
"Three months" doesn't indicate anything, unless it's losing that much coolant when it's parked for three months. What DISTANCE are you driving in that time?
Best way to find a "phantom" leak is with a pressure test. You replace the radiator/reservoir cap with a special cap with a valve, and pump air under pressure into the system. This will cause the leak to manifest at room temperature, so it comes out as a liquid rather than steam. Being a '95, your truck might have a radiator cap rather than a reservoir cap. You should be able to borrow the tester from your FLAPS on their tool loan program.
'Course, it might be the radiator/reservoir cap itself.
Some of the FLAPS pressure test kits don't include a test cap for an external reservoir like ours. (Baffling, since they've been around for 20+ years; my Saturn has the exact same style cap.) You may have to fashion your own. If you happened to save your old cap, you can drill a hole in it, and install a tire valve. May need to seal with RTV. Then you can just pump it up with a hand tire pump.
There's always a risk that coolant will boil out when you remove the cap. But with a reservoir, you have a lot more air space above the coolant level, compared to an old-style cooling system with a radiator cap. So yeah, there's less risk. Is there at least some pressure release when you remove the cap when it's hot?
What the heck?!!! Is this a joke? That guy does not have a clue! You need an SCA additive/fleet coolant. That "parts" guy needs to be flogged and sent on his way. Use Fleet Charge Coolant and Distilled water. the coolant can be purchased at Napa.
