Updates on my PO299 while towing
Like the title says, I pulled my camper home today and the truck worked great! I cleaned the MAP hose and nipple and also cleaned the EBP tube and sensor. Also the numbers you all gave me for my scanguage fixed the negative boost issue and that is reading like the dash gauge, I see 27.5 at one point so I believe the turbo is working as it should....deltas were great too, the warmest I see the coolant was 207 and the EOT went to 217 once briefly and that was in a long pull on a steep grade pulling from a near stop mostly though during the entire ride home (approx 50 miles) they were 190 ect and 198 eot. All is well in the world tonight.
Me too Rusty, and thanks for the help with the PIDS on my scangauge....I had tried about everything and had gave up. My truck is now working better I think, than anytime since I've owned it. All jokes aside I do believe the HHS I put in this past oil change has quieted the injectors down and the engine starts quicker and seems to run smoother than it ever has too. I haven't kept that good of records on fuel mileage but I'm sure it didn't hurt that either. I'm going on a trip this week with the truck/trailer and will try and get some kind of accurate mileage reading just to post something up for others to see/compare their trucks to. Thanks again for all the help you offer on this site and the others I see you on too.
Monster Moovers
09-17-2014 04:09 PM
jamesbfishin
03-21-2004 11:52 PM
