65 CS clutch. How would you have done it?
So I have a 65000 original mile CS. Most likely original clutch. Bad throw out bearing.
First choice: Pull the interior out to get access to trans. pan? (knowing that as soon as you try to lift up the original old floor mat it will crack)
Second choice: Lift cab up off frame.
Third choice: Pull motor and trans all at once.
Trans. is out. Just needed someones shoulder to cry on.
Notice in the pic that the original throw out bearing (7580) used a separate collar (7561). The bearing had to be pressed onto the collar.
1970: FoMoCo changed the design, the bearing and collar became a one piece assembly.
btw: As part of the package, 352 Camper Specials were only available with MX Cruise-O-Matic or the Borg-Warner T-18 4 speed.
No 3 speed manual trans was available....with either the 352 or 300 I-6. The 240 I-6 was also not available in Camper Specials.
And since my floor mat is so shot as to not worry about further cracking, I guess I don't have anything good to add to the original post!
One good thing about cracking the floor mat is to look and see how much "wet boots"-caused rust there is on the floor pan from water collecting under the floor mat. Even though the floor pan on mine looked solid from underneath, there was a lot of rust on the interior surface, which I am now planning to take care of. Without cracking the floor mats, I never would have known it was there.
1965/66 F100/250 2WD's could have either the Borg-Warner T-18 or the New Process 435 (NP435) which I forgot to mention in post 3. F350's & 4WD's were only available with the NP435.
T-18: Reverse is up...towards the dash, shift lever retainer cap threads off/on.
NP435: Reverse is down...towards the seat, shift lever retainer cap has two notches, is retained to the shift tower with two pins.
customcab66
11-17-2006 03:36 PM
djshoser
12-30-2004 06:42 AM
