Any updates what gas engine will they put in the 2017?
#76
It will be interesting to see over time how effective that method is, considering as engines age, more combustion products end up in the crankcase. It seems to me that eventually the crankcase byproducts would be high enough that just washing the valves when cold, wouldn't be enough to keep up. Bring on the walnuts!!
#78
#79
With the new aluminum sections, It will be 5-700 lbs lighter. So, even if they didn't make changes to the engine line up, they would all perform better.
#80
Unleaden yes, but Ford is keeping GVWR the same which provides more payload than before. So theoretically, fully loaded, the same engine would be moving the same amount of weight.
#81
I really feel like there's more power in the 6.2 than Ford is letting on.
#82
5 Star Tuning found 30HP on the dyno with the 6.2L. That's a lot for a gasser, and Ford can still mess with the cam. Not bad for old-school base engine architecture, definitely a solid base fleet motor.
#83
5 star tuning just simply found the roughly 30hp that Ford detuned out of the SD. Keep in mind the Raptor and F-150 had 411bhp/434lb-ft stock. The only reason Ford removed that extra power and torque was to protect the, at the time, 390bp 6.7L diesel. Despite having a lot of torque, customers don't like paying a big premium for an engine with "less" horsepower than the base gas engine.
But this engine has the potential to make much more horsepower. Ford built the elusive "Raptor XT" in 2009 which produced 500bhp and had no power adders such as turbos or supercharger. Forced aspiration models, such as the 600HP "Velociraptor" or the Roush model with up to 700HP.
The 6.2L has a very solid foundation to produce much more power and torque should Ford choose to upgrade it. Ford could easily add 4V heads, and then adopt the Ti-VCT from the Mustang / F-150 instead of the De-VCT which the engine has now. The engine was designed for direct injection from the start - with the bosses for the injectors already in place. Even in 2V form, more aggressive cams would bring more power. The 2V design allows for very large valves, which are splayed to allow them to fit. Roller rockers reduce friction, and of course, there are dual spark plugs - mainly to accomplish full combustion, due to the splayed valve design, but there are other minor advantages to the dual plug setup.
The biggest drawback of the 6.2L is fuel consumption. DI would help slightly, but in reality this engine is going to burn gas. With much stricter EPA regs in place - such as the 2019 mandate for even "HD" trucks to be rated - I think Ford's priority will be MPG followed by power.
#84
This is the same disappointing news that I heard as well. I was so hoping for at least the 5.0 as a option and had my fingers crossed for maybe an eco-boost something.
#85
#86
The Eco Boost is an interesting proposition - but I much prefer the CGI block of the 2.7L than the aluminum 3.5L. The current Navigator tune - 380bhp and 460lb-ft - would make for a nice setup. Really, though, 400bhp and 500lb-ft would be excellent.
My preference, however, would be to simply give the 6.2L direct injection, and bump the power level to 400/450. I really like a big-displacement gas V8 option in a truck.
#87
The 6.2 is pretty good the way it is. At some point more power isn't better than making a tank of a motor that does the job well and goes forever. The transmission will still be the bigger factor to watch for here, and if you want to mess with the motor, there is plenty of room to breath heavier on the 6.2.
#88
Since the 6.2L and 6.7L share essentially the same trans, there is a LOT of room to juice up the 6.2L without worrying about the trans.
I'd be very surprised to see the 10-speed on the new Super Duty. It's a joint GM-Ford venture. Ford uses the same trans, gas or diesel. GM uses the Allison on their diesel. So either this will be a "gas-only" trans for both Ford and GM, or GM will stop using the Allison on their diesels (which has been a big marketing point for them). Thus, I suspect the 10-speed will be on the 1/2 tons only.
#89
Ford told us to expect a new transmission for gas SuperDuty. Not sure if it will come with the 2017 or not. Yes, the current trans is more than robust enough, but the added gears will allow better start-ability and grad-ability for the gas models. Believe it or not, the $8k tag of diesel isn't pure profit. Ford would be more than happy to take up market share of the gas models, which make up a bigger portion for the 250/350 line. Ford likes gas, look at the v10 they use all the way up through the medium trucks.
#90
Where did you find information stating there would be a new transmission for the next-gen SD? I know the 10-speed has been confirmed for the Raptor.
Actually, the current 6R140 trans has a very low first gear. The advantage to more gears would simply be a greater ratio spread throughout, which as you say is advantageous to mpg and going uphill. It is true more gears could allow for an even lower 1st gear, but I don't think it would be needed.
I know the now $8400 for the 6.7L is not all profit, but based upon the amount of marketing for diesel vs. gas (I basically never see the gas advertised), it seems Ford wants you to buy a diesel...which makes me think they make more profit on it vs. the gas. Ford has also hobbled the current gas engine output, in my opinion, to force customers to buy the diesel.
