No rear lights at all!!!!
I searched and could not find an problems similar to mine. My new body style f150 , all the rear lights have quit working.whats really odd is at first it was the left signal then the right then everything. All bulbs are good. If I pull the bulb out and test for voltage i get voltage, I replace the bulb and test again.....NOTHING. I took the rear ground off and cleaned it up, test fusses . Don't know what to do from here.
The first thing you need to do is change your troubleshooting technique. Then I think you can make some progress on your problem. I will try to hunt up a diagram also.
You need to use a testlight or leave the bulb in the socket and poke the wires with your meter. You have to keep or put a load on the circuit or you will get weird readings like you are now. A testlight is really the best way and they are cheap at Harbor Freight. They have a very sharp point on them also so it's easy to poke the wire, but with a testlight it presents enough load to where you could probe the socket like you are doing and get a good reading.
