7.3 Noisy at idle
7.3 Noisy at idle
1991 7.3 overhauled a year ago. IP started having to be watered to get it to start hot. At the same time it started to really rattling at idle. Replaced IP and problem idle noise is still there. Come off idle it sounds good runs good. Oil pressure is good temp is good. Seems to be noisier underneath and and in the torque converter area. TC nuts are tight it is a c6. Any ideas folks
Did the tone of the engine change? If not, you're doing something wrong.
It might not change your clatter, but it should change the engine tone.
Make sure you are pushing on the bottom of the lever, or pulling on the top.
Not sure about the lever? If you push the throttle lever towards full throttle(or have someone step on the gas), you'll see the lever on the side move in and out.
Received 3,102 Likes
on
on
here is one on evilbay with the outer anticrack ring. not sure if it is for the C-6 though:
http://www.ebay.com/itm/1987-1991-FORD-6-9-7-3-IDI-DIESEL-FLEX-PLATE-ASSEMBLY-FOR-AUTO-TRANSMISSION-/221844712848?hash=item33a6f9ad90&vxp=mtr
here is another one, but like the one above they do not say if it came off a C-6 or an E4OD.
and i don't know if there is a difference or not.
http://www.ebay.com/itm/88-89-90-95-96-97-FORD-F350-FLYWHEEL-FLEX-PLATE-A-T-8-445-7-3L-DIESEL-48463-/252027445483?hash=item3aae01a0eb&vxp=mtr
on
as per www.car-part,com in Oklahoma:
<table width="100%" border="1" cellpadding="4" cellspacing="0"><tbody><tr><td>1984
Flywheel/Flexplate
Ford Truck 250</td><td>AUTO,RING GEAR</td><td align="center">C</td><td>980208</td><td align="center">$45</td><td>Bud's Salvage USA-OK(Aline) E-mail 1-800-375-2837 1-580-463-2424</td></tr><tr><td>1986
Flywheel/Flexplate
</td><td>FLY W-O FLEX PLATE</td><td align="center"> </td><td>KS793</td><td align="center">$45</td><td>Bud's Salvage USA-OK(Aline) E-mail 1-800-375-2837 1-580-463-2424</td></tr><tr><td>1987
Flywheel/Flexplate
Ford Truck F250</td><td>FLEX PLATE ONLY</td><td align="center"> </td><td>NOF</td><td align="center">$Call</td><td>Lawton Auto Parts USA-OK(Lawton) E-mail 888-355-7758 / 580-355-7757</td></tr></tbody></table>
Flywheel/Flexplate
Flywheel/Flexplate
Flywheel/Flexplate
mOROTBREATH
09-02-2010 12:11 AM
Diesel Mechanic 08
13
02-09-2010 01:56 PM
