2006 F350 DRW electrical issues Help Please!!!
If I am reading this right with key off and the cluster plugged in.
Pin #4 should not be grounded. If you find that it is don't change
anything and wait 30 minutes and recheck. That should give it more
than enough time to reach the time-out period and lift the ground.
On the wiper motor it's on F2.33 Should be hot in RUN and ACC.
The only thing be tween it and the wiper switch is the ignition key
and swith assembly.
I attached the power distribution PDF for you in 2 parts.
Sean
6.0L Tech Folder
and swith assembly.
Sean
6.0L Tech Folder
fishheds
05-08-2013 07:02 AM
