Test for fuel in coolant?
Try dyed offroad diesel and distilled water. The distilled water should remain clear, but if it develops a red tinge at the edges of the water level in the degas bottle, I'd suspect that the dyed off road diesel is present.
That was my indicator.
Wasn't sure at first, coolant smelled funny. When I continued towing heavy, I noticed the red tinge of diesel contamination.
Given, it's a farm vehicle and using off-road diesel on highways is not advocated. I feel that I must state the fact that it's illegal.
Thanks to the replies. I think what I am seeing is left over oil residue from an earlier oil cooler O-ring problem. I flushed the system several time but never did any "cleaners". It does not smell of diesel and there is a slight sludege on the degas cap and the surface of the coolant, but this has not changed in over a year. Coolant level has remained unchanged.
Diesel will destroy the rubber gasket on the thermostat as well as make your radiator hoses very soft.
If you're diesel mix in your coolant lines, you'll end up with a lot of hoses needing to be replaced and your degas bottle will overflow from the excessive fluid
keep a watch on it! Post pics too.
