Throttle Position Sensor goes bad every 6 months or sooner
I will report back on this and let you guys know short term and long term.
One of the biggest issues with the dorman is that it isn't actually designed correctly. Once you install it you have to turn it (preload)to get the bolt holes to line up so the PCM is seeing some off readings cause the tps and I've or not times correctly and the fact that they are just junk.
jstihl
12-23-2017 08:18 PM
AGrayson84
1997-2006 Expedition & Navigator
11-08-2016 02:56 PM
Franko72
04-27-2011 09:36 PM
