no battery light / no charge
I am having a charging system issue.
the alternator is making barley over 12 volts. With KOEO the battery light on the instrument cluster does not come on. I have already replaced both batteries and the alternator -before i noticed the battery light is not coming on.
any ideas?
any ideas?
Does it ever come on during start up and are you sure it's not a bulb?
Also, check the plug at the back of the alternator. I've seen the wires break there and give weird readings and no voltage. Also, what kind of alternator and are you absolutely positive the "new" alternator isn't bad? Wouldn't be the first.
Diverdan0430
06-19-2017 02:30 PM
duden123
1999 to 2016 Super Duty
20
09-10-2006 12:32 PM
