Tow 78 F150 4X4 using a tow bar???
Hey guys. Would it be OK to tow a 78 F150 4X4 s-cab using a tow bar???
I have just bought this and am pretty sure I can get it running and drive it home (about an hour and 20 minutes away). If not, my backup plan is to use a friends truck (with plenty of towing capacity) and a tow bar. Would this be a bad idea? I know I will need to disconnect the rear driveshaft and wire it up.
Could someone be in the truck being towed to operate signal lights?
Thanks.
Thanks.
Thanks.
Thanks.
If you use the tow bar see if you can remove the front bumper and connect to the frame horns, and look into getting some magnetic tow lights for the back end.
Have the guy doing the driving, tow it like any other time he tows anything. Think ahead, ,plan on extra braking distances, drive smart.
I would guess it might be illegal to have some one in it, if you are towing with a hard connection?? And it might be illegal all together to tow with a soft (strap) connection??
I would high a roll back wrecker and be worry free on the move. Yes it is costly, but so is an accident.
Be safe.
Be safe.
My local Sunbelt rentals has 10k rated equipment trailers that work great for heavy long PU's. Tilt bed is easy to load. Surge brakes that work pretty well. They require a 2 5/16" ball
Cost to rent local is about the same as a Uhaul car hauler. ~$60/day last time I did it. I am sure other rental houses have similar... I think this would be a lot better/safer vs a tow bar.
PS: you need tie downs or load chains to secure the PU. Sometimes the rental house will loan or rent them or supply your own.
So, in the end, no towing needed. Replaced the fuel pump and fuel line from the pump to the carb. Put in a new battery and it started right up. Purred like a kitten. Had to add some brake fluid for the front disks so that will need to be checked out, but drove the truck home, about 80 miles, with zero issues.
Even used the gas in the tank. I am now convinced that fuel stabilizer works. We drained some of the gas into a bottle - it was clear, no bad smell, tasted perfect (just kidding) . So we hooked up the line and away we went.
The truck is now at the mechanics to see what it needs to pass a safety inspection.
Thanks for all the help and advice guys.
Shenna Tipton
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-22-2015 12:19 AM
