06 F350 Mirror Wiring Needed
Old 07-17-2015, 09:23 AM
Martyn Allison's Avatar
Martyn Allison
Martyn Allison is offline
do you by chance know the colors of the wires in the 7 pin plug at the mirror, some one has ripped them out of my mirror and I just need to know the sequence of colors V numbers 3 thicker ones are in place, 4 thinner ones have been pulled out
Any help would be very much appreciated
Old 07-17-2015, 01:59 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
This is all I could find for the door connectors.
Old 07-17-2015, 03:27 PM
Martyn Allison
ha ha,, its not the door mirror connections its the mirror on the windshield
It has a 7 wire plug,, some o
ne has pulled 4 out of the 7 wires out and i want to return them to where they came from
Old 07-17-2015, 08:35 PM
Franklin2's Avatar
Franklin2
I will let you look for it. Their connecter views are not really organized, so it takes a while to find it. I remember seeing the wiring diagram for the inside mirror, but I am not sure they have the connector view. But they probably do, you just have to keep looking. They had like 15 sections of connector views with spotty diagrams in each one.
Go to autozone's site and register.
Plug in your truck. If it doesn't work, plug in a 2005, their diagrams go to 2005 but 2006 seems to be mostly the same.
Go down and click on repair, and then repair guides. Click on wiring diagrams, and the scroll down to connector views. Then click on 2005 connector views. Then go back up to were you clicked on 2005 and you will see lots of 2005 connector view files. They are not labeled, so you have to go through each one and look through all the diagrams till you find it.
Old 07-18-2015, 08:22 AM
Martyn Allison
Thank you I will go look now
Old 07-18-2015, 09:15 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
C911 at the mirror only uses three wires/pins. The other 4 pins of the connector are "Not Used" which means they may never have had wires in them in the first place.
Pin #1 of the connector is your F45 circuit, red/yell wire which also goes to the compass module, if equipped. Pine 2 is black/ground, pin 3 is HOT IN REVERSE, black/pink.
Old 07-18-2015, 10:12 AM
Martyn Allison
Thank you so much,, so the 4 wires are not used,, where the heck am I going to put them hahaha no rude comments hahaha
Ok thanks you have been so helpful,, I now have an awesome truck, it is replacing my 04 F250SD, all that's left to do is replace the speed sensor on one rim and a glow plug on #1 and its exactly what I want,, a good reliable pulling truck
LSCRX
07-29-2019 08:39 PM
smarty39
1999 to 2016 Super Duty
06-23-2015 02:35 PM
1MrBrian1
10-29-2014 09:03 PM
hammer65
06-06-2012 07:38 PM
Quick Reply: 06 F350 Mirror Wiring Needed
