1953 F100 292 Trans Advice
HEF-AU = 1964 F100 292 114" wheelbase & 1964 F250 292 4WD with 120" wheelbase.
HEF-AV = 1964 F100 223 114" wheelbase & 1964 F250 223 4WD with 120" wheelbase.
1963/66: Ford used H prefixes for the 3.03. 1967/76, the 3.03 prefixes were RAN & RAT
Post 18: inre to Borg Warner T-85: This is a 3 speed manual with overdrive, the first gear is non syncro'd. The 3.03 is fully synchronized.
T-85 installed in 1965/71 F100 240/300 I-6; 302 (1969/71); 352 (1965/67); 360/390 (1968/72). 1941/48 V12 Lincoln Zephyr/Continental, 1948/51 Lincoln/Cosmopolitan with 337 V8 flattie.
And 1955/56: Hudson/Nash, Packard/Clipper; 1956 Studebaker Golden Hawk (all these came with Packard V8's) and etc etc etc!
Big Dummy no longer MIA
Hey guys. Need your help again. So I ended up finding a 3 speed trans out a 55 that I decided to mate up to the 292 y block that I have. I ordered a new clutch kit for the 292, installed it no prob but towards the end of the install I noticed I did not have a throwout bearing hub. I did some searching around and ended up with NOS part B3TZ-7561-A which I assumed would work fine for my application of mating the older style trans to the 292 out of the 59. The throwout hub fits fine on the trans and the fork on the bell housing but not so much on the throwout bearing itself. As you can see from the pics the diameter on the bearing is bigger than the hub. Any suggestion on what to do here? Do I need a different hub or a different bearing?? Thanks for all the help.
Thanks for the reply. It's a 10 spline but the shaft diameter is 1-3/4". I pulled the tranny out of a f100 panel and judging from what I saw it definitely appeared to me to be original to the truck.
