My truck is destroying my plug wires
Old 08-28-2015, 12:39 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Dixie, the PCM compensates for the lack of the SPOUT, you remove it with the engine off so the PCM acts like it's in place still, otherwise it will try to correct the timing to the previous value.
  #32
Old 08-28-2015, 01:27 PM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
I disagree with that theory.
  #33
Old 08-30-2015, 02:28 AM
Encho's Avatar
Encho
Encho is offline
That was my understanding of what was explained to me when I was told the procedure, but I know you're way more knowledgeable when it comes to the electrics/electronics of these trucks, please explain.
  #34
Old 08-30-2015, 12:41 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
Just food for thought:
When applying the dielectric grease (silicone) to the boot, I believe it should coat the entire inside of the boot, all the way up to where the wire connects to the plug.
I know your issue was apparently excessive heat from bad timing, but the coating on non conductive grease would have helped eliminate arcing to the block if that had been the problem.
Glad you got it figured out!
  #35
Old 08-31-2015, 07:58 AM
rla2005's Avatar
rla2005
The SPOUT signal comes from the computer to "bias" the TFI trigger timing. TFI is also referred to as the Ignition Control Module (ICM). This is how the computer controls the timing based on sensor input. With the SPOUT removed the TFI will trigger on the raw PIP signal.
By removing the SPOUT signal path there is no way the computer can bias the timing. It really makes no difference to remove or install the SPOUT with the engine off versus engine running.
  #36
Old 08-31-2015, 08:13 AM
dixie460's Avatar
dixie460
dixie460 is offline
That's what I thought. Just making sure the ICM wasn't smarter than I figured it was.
  #37
Old 09-05-2015, 08:05 PM
speedy7201's Avatar
speedy7201
speedy7201 is offline
Very unusual. Something I've never heard of. However something is definetly shorting out or overloading and in the same plug wires, wow.
Let us know if or when you find out.
Type the problem into google search and see if anything comes up, you would be surprised.
carchub
03-09-2013 10:21 AM
460GasMeister
03-24-2011 07:41 PM
Nightstalker
Bronco II
01-07-2007 10:22 PM
94FordGuy
Aerostar
21
11-02-2004 11:27 PM
christop43
1978 - 1996 Big Bronco
11-23-2002 09:06 AM
Quick Reply: My truck is destroying my plug wires
