1950 f1 with gm subframe. Anyone wanna look to tell me more??
The increased demand for/rise in prices on that era Nova and Camaro and the age of the parts/engineering along with the change in fashion to MII IFS and F in F drivetrains has reduced the number of people doing this swap today.
As long as the balljoints, brakes, steering parts are in good shape there is nothing "wrong" with this install. If you really want to change the engine to the more "fashionable" Ford, it's not difficult to do. Tony is following the trends, pulled the CSB that was in his truck and we built mounts to install a pushrod 5.0 FSB in his, a fairly easy fab, but space front to back with the FSB was at a premium and needed a fair number of mods.
I am currently helping another friend, Gary install a 4.6L 3V Ford Mod motor in his F1 with dropped beam axle and Toyota PS. Finally got the header problems worked out and tomorrow we will be fabbing the motormounts.
Ill be likely using my 4.6 DOHC and T56 combo for it. Putting a LS motor would be a lot less pricy on a rebuild in the future but I like the idea of keeping it as ford as possible. I know my 4.6 has about 93K on it, and needs valve guides, not sure how much deeper ill go but that could get costly if I go to crazy im sure. I got a quote on the Ron francis harness and PCM/ECU flash and would likely use that as well.
cashy52
46
03-08-2021 12:17 AM
bigbozz
05-23-2015 05:01 PM
John & Old Ford
19
12-19-2013 02:22 PM
Cody_1948
06-17-2011 11:04 PM
jmadsen
19
02-06-2010 10:00 AM
