Pulley Removal - Crankshaft & Water Pump
on
How do you remove a Crankshaft pulley?
How do you remove a Water Pump pulley?
I don't see why I'd keep all my V-belt pulleys when I have access to a serpentine 351W set up at the local pick-n-pull on a newer truck (1981 F150).
The plan is to change out all my V-belts on my 1972 351W engine to the serpentine set up on the 1981 351W in the local J/Y.
The harmonic balancer requires a puller, but if you're just removing the pulley from it, that's a simple matter of take the 4 bolts out and pull it off the front of the balancer, just like the water pump pulley.
The power steering pulley is the only one that should require a special tool for the pulley itself (though breaking the nut loose on an alternator is sometimes non-trivial).
2x on the crank pulley... balancer is a different aminal.
on
The crank puller/installer I've got sitting in the garage is this one:
But I'm curious if what I need is this one...:
The water pump pulley sounds like it comes off relatively easy. So if I have this correct... the water pump pulley doesn't require a special puller (like our power steering pumps do)?
That first puller would work for the harmonic balancer, but you shouldn't need to pull the harmonic balancer off the crank - leave it and the center bolt in place, and there should be a few smaller bolts that attach the pulley to it. It should come right off with no puller.
Same with the water pump - pull the 4 fan bolts out, and it should slip right off the pump with no puller.
Here's a picture during my engine assembly that shows the harmonic balancer installed without the pulley attached - you can see the 4-bolt pattern: pull those 4 bolts out, and the pulley should come right off the front of it. Same for the water pump above it - just the 4 bolts to take out, and it's free.
on
That is fan-freaking-tastic news.
I can't think of any reasons I wouldn't pull those pulleys from that 1981 351W engine out in the J/Y. I could be running a serpentine set up in no time at all!
To hell with the V-belt pulleys!
At one point I was told that I need a reversed water pump for my 351W because a serpentine set up would turn the water pump the wrong direction. How does a person tell which way the water pump turns under a regular v-belt set up?
Look at the belt routing: with a V-belt setup, everything will turn the same direction as the crankshaft, because the belt never doubles back and runs the back side on anything. With a serpentine setup, you can run some pulleys on the smooth side of the belt, and these will turn the opposite direction of the crankshaft. With the water pump, direction of rotation is important due to the impeller design, so you'll need to swap the water pump if you plan to spin it the other direction. Just buy one for whatever application you're getting the accessory drive from.
The other thing to pay attention to is pulley alignment. Measure and be sure that the pulley mounting surface of the harmonic balancer on the crank of your engine is the same distance out from the block as the same surface on the engine you're pulling the pulleys from. I expect it'll be the same, but measure just to be sure. You might have to swap balancers if the spacing is different, even though the pulley would bolt up fine to your balancer, just to get the pulleys lined up properly. As with the water pump, you should be able to just order the balancer that would fit the application you're pulling the accessories from.
Since I was cobbling a mis-match of different-year parts for my build, I ended up switching from the one pictured above to this style harmonic balancer with removable spacers (I had the 50-oz imbalance one, but linked to the 28-oz one here, which would be right for the 351W):
http://www.summitracing.com/parts/pf...view/make/ford
There are three different spacer thicknesses that can be put on the front of it to get the pulley spacing right:
http://www.summitracing.com/parts/pfs-81006/overview/
http://www.summitracing.com/parts/pfs-81007/overview/
http://www.summitracing.com/parts/pfs-81008/overview/
I don't think you'll need to worry about that, but it is an option if it comes to it.
on
If I don't get it all on the first try, I might be going back several times (which would be annoying).
Hopefully everything I need is still there when I go back!
saleen065
09-08-2008 09:49 PM
Unglued
10-09-2004 09:51 AM
