2001 F-150 SC 5.4L radiator issue?
Went to start my truck to leave work yesterday and blew the coil on #2. It's happened before and I can fix that. The other weird thing that happened was that the radiator leaked out some antifreeze. Not a lot, but a good 2 foot puddle. The reserve was still full and it leaked from the passenger side at the bottom (below the upper hose). Upper and lower hose show no sign of leakage. I suppose the drain is on the lower end of the passenger side of the radiator and it leaked from there. Would the compression from the engine cause that to happen? Or is it something more, dare I say, like the head gasket blew?
I appreciate any insight!
antifreeze usually leaves a trail. i would try to follow it. Coming from the radiator bad radiator, coming from the engine- more possibility's. Their are also HG test kits that have a chemical that changes color if it detects combustion fumes in the radiator. $30 dollars to know is a cheap way to eliminate/confirm the HG
While ive not had a ford do that to me. I did have a Nissan run atleast 50k miles while i changed out the radiator 2 times. Multiple long trips. Just dont over heat it and carry some radiator fluid. (if i had to do it over again i would have just fixed the problem)
trucker01
05-18-2009 11:11 PM
Franklin2
11-03-2007 05:14 PM
