Rickys '96 F-250 build thread
Old 07-17-2015, 01:28 PM
Hussler's Avatar
Hussler
Hussler is offline
Originally Posted by dieselhead1052
The next project (hopefully September) is rebuilding the EBP system with an EBPV deleted pedestal, non-EBPV hi-flow outlet, EBPV actuator isolator pigtail and replace leaking pedestal o-rings.
Give yourself some time on that project. Just recently did that and it took me 2 days to get the pedestal / turbo off. Thought I had every tool needed .. I was wrong and had to make a few. Once off I upgraded my upper electric fuel system and installed the EBPV deleted pedestal and hi-flow coupler to down pipe. Only took me 1 hour to reinstall new pedestal and turbo.
Good grief, never want to go thru that again, I'm still healing ...
Old 07-17-2015, 02:05 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Originally Posted by Hussler
Give yourself some time on that project. Just recently did that and it took me 2 days to get the pedestal / turbo off. Thought I had every tool needed .. I was wrong and had to make a few. Once off I upgraded my upper electric fuel system and installed the EBPV deleted pedestal and hi-flow coupler to down pipe. Only took me 1 hour to reinstall new pedestal and turbo. Good grief, never want to go thru that again, I'm still healing ...
lol. Lol. I remember doing that to. A lot of penetrating oil and head scratching went into that project. Custom tools were made on my end too lol
BBslider001's Avatar
BBslider001
BBslider001 is offline
This is ONE job I paid to have done. I just didn't have the time or the desire to put myself out like that.
Old 07-17-2015, 09:38 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I've done it two times, now I'm looking at a third. Maybe I'll hire it out like you Bryon!
Old 07-17-2015, 11:55 PM
BBslider001
It wasn't bad Glenn. Guy charged me $190 for labor. Saving my hands and the time/frustration was more than worth it to me.
Old 07-18-2015, 11:31 AM
dieselhead1052's Avatar
dieselhead1052
dieselhead1052 is offline
Wow $190? Nice.
Old 07-18-2015, 07:44 PM
BBslider001
Wow $190? Nice.
Yeah, and on top of that, it was a local guy who does 90% of his work on 7.3s. He's drives a 2000 SD, but is very knowledgeable about the OBS. He said he had the turbo off in about 45 min. He did say it wasn't "welded" on there though like they can be. All the bolts came out pretty easily.
Old 07-21-2015, 01:10 PM
dieselhead1052
Your location says SoCal, this guy wouldn't happen to be in San Diego would he?
Old 07-21-2015, 01:17 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
Yup, pulling the turbo is a bad job.
Old 07-21-2015, 01:34 PM
madMatador78's Avatar
madMatador78
madMatador78 is offline
Ask me how I know about pulling the turbo, I got the pleasure of pulling it 2 times last week in a camp ground, and I did it a few months ago too, I'm becoming an expert!!! lol
One thing I will say is make sure to never seize the snot out of the hardware when you put it back together. Makes future dis assembly a breeze.
Great looking truck! I'll be looking forward to watching your progress!
Edit: also put some grease on the o-rings when you set them in their respective holes, my lack of doing that was the reason it had to come back apart, its very easy to bump them out of place, then you will have yourself a real mess.
Old 07-21-2015, 02:29 PM
BiGGreen350's Avatar
BiGGreen350
BiGGreen350 is offline
honestly ive done 2, both coming off were factory pedestal with ebpv, and both times going back on were post ebpv delete and goes easy.
I really wasnt impressed with the hype of difficulty everyone said it would be. I have them out within 45 minutes to an hour.
i take the down pipe clamp lose and push downpipe to side,
then remove the exhaust housing from the turbo with the 3 12 point bolts.
then for the 4 pedestal bolts i use a 1/4 inch drive 10mm swivel socket with an extension, and then sometimes an adapter to 3/8 drive if they are really on there. only had to do that twice.
and for the 4 flange bolts i use a 3/8 drive 15mm swivel with and extension for 3 of 4 flange bolts, and on the fourth i use a small stubby box wrench,
and walla its off.
alot easier going back on with the ebpv cylinder out of the way
Old 07-21-2015, 03:09 PM
dieselhead1052
and walla its off.
Yep I got the swivel sockets on order!
BTW, are you running those 35s on stock ALCOAs?
  #28
Old 07-21-2015, 03:47 PM
BiGGreen350
that'sthe way to do it, the swivels help a ton, i went into it thinking id have to create some custom tools but i did great with what i just listed
i do however understand peoples level of difficulty varies a bunch, and i have been wrenching for awhile, its all relative to ability and comfort doing this stuff
yes factory alcoas!! I love them!
  #29
Old 07-21-2015, 04:25 PM
cowmilker08
Nice truck, Matt! My only difficulty was the nut that you used the stubby wrench on. I had to weld up a custom tool to be able to put a cheater pipe on it to get enough torque to break it loose. In the end my moment arm was about 2.5 ft.
  #30
Old 07-21-2015, 04:49 PM
BiGGreen350
Thankyou!
yeah that one can be tough!
Quick Reply: Rickys '96 F-250 build thread
