97 Explorer - no start - Already replaced parts...
As title suggests...I picked up a 97 Explorer with the 4.0 SOHC engine.
Turns over, strong gas smell...no start...Hit the forums
As per suggested on here started replacing parts.
Relays, fuel pump, spark plugs & wire, maf & iac have been switched out.
Turn the key, fuel pump kicks in and stops, kicks back in when trying to start the truck too...So ran a wire to the inertia switch to keep the pump running...Still no go.
Has gas, has spark (tested)...what options are left? Timing? Computer?
Do you know if the fuel is any good? Do you have a way to test the fuel pressure to make sure it is within specification? Is all the intake air tubing good and securely connected? You should confirm (if it wasn't done when changing the MAF) that the air filter box does not have a nest in it plugging the air intake.
-Rod
-Rod
uzaki474
03-28-2015 01:56 PM
Explorer180
03-15-2011 10:32 PM
olsonew
09-20-2007 08:00 PM
chili97
07-10-2002 08:51 PM
