My first Ford F6 1948
Just picked up my new, well new to me, 1948 Ford F-6 truck. I had a 1950 Dodge (I know) truck close to 20 years ago. I'm not an expert by any means. I looking for some guidance (props to harleymsn). I'm in need of getting it running. I've been told by the seller it has a rebuilt engine, a new/rebuilt carbonator, the transmission might have been rebuilt, the body looks great. The bed is flat and wood. The tires look like a mess, the brakes don't seem to be working, except for the parking brake, the clutch I was told was in need of a "fork Adjustment" the clutch peddle goes to the floor, so does the brake. I was told it was converted to 12v.
I'd love to find a shop or traveling mechanic to get this running safely on the road. I'm in Milton, GA. I hope I can post pictures (but don't seem to be able to yet on this forum???), and I owe one more pic of the dash (when I can post) since their are switches for high/low gear selection?
And to beat all, no keys were provided. And there is a strange switch on the steering column.
I just joined as premium since I don't mind paying for a good forum.
Thanx!
Thanx!
Very nice looking truck. Brakes are fairly easy to do but the biggest hurtle with these big trucks are the WM wheels. Looks to me like you have multi-part wheels but not the dreaded WMs. Looks like there isn't the thick band on the concave side of the rims and on the picture of the front wheel it looks like a snap ring type set up. If they are the type with outer snap rings truck shops will still service them.
Welcome!
It does appear that the carb has been refreshed - at least cosmetically - and the head bolts have been replaced. Usually signs of real work having been done on them. Hard to tell about the electrical - didn't get a good look of the generator/alternator or the battery rating. If you need to replace the radiator cap, be certain to watch the rating - yours should be a 4 pound version.
On the brakes. It appears that the lines have been refreshed. I would check the fluid level in the master cylinder - under the floor by the driver's right foot there is an access disk. This should be a booster system that has other components that may be at issue if the fluid is ok.
The biguns' are a special challenge - they do have their own honest style. Thanks for sharing.
