I beam swap
Old 07-14-2015, 07:35 PM
Dean6586's Avatar
Dean6586
Dean6586 is offline
I beam swap
I'm looking at getting a set of I beams from a 67 an up f100 will they still work on a 65
Old 07-14-2015, 10:01 PM
37 Ford guy's Avatar
37 Ford guy
37 Ford guy is offline
Yes, F100s & F150's up thru 1979 will work. If you're considering disc brakes, find a '73-79 donor. Ibeams, radius arms, etc will bolt on to your '65.
Old 07-15-2015, 03:00 PM
sawmaned's Avatar
sawmaned
sawmaned is offline
ibeams
didn't 65 come out with twin I beam,it was the first year for that front end,i have a 65 that I am parting out you can see in in the parts section,it has complete front end if interested,if not I have a 69,70 twin I beam front ends thanks ed
Old 07-15-2015, 04:51 PM
jowilker's Avatar
jowilker
jowilker is offline
Dave, You willing to share why you are looking for 67 up I-beams? What are you needing bro?
John
Old 07-16-2015, 09:12 AM
Dean6586's Avatar
Dean6586
Dean6586 is offline
Ok so my wording was a bit off my 65 does have the twin I-beam set up, I was wondering if the 67 and up are the same size as the 65 I'm a certified welder and am looking at using a old set to make drop beams
Old 07-16-2015, 05:07 PM
jowilker's Avatar
jowilker
jowilker is offline
The 67 beams should be identical to the 65. Starting in 73 they would have had disc brakes instead of drum.
John
Old 07-16-2015, 05:30 PM
sawmaned's Avatar
sawmaned
sawmaned is offline
part
if you haven't got any ibeams yet let me no I have a set off a 65 and 69,70 thanks ed
Old 07-18-2015, 02:49 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Same R/L I-Beams: 1965/70 F100/250 2WD; 1971 F100/250 2WD before serial number M00,001.
johnmel59
11-02-2014 03:20 PM
MeanMan66
06-19-2008 10:57 PM
who243
11-14-2005 10:16 AM
rs2600
06-07-2005 04:18 PM
Quick Reply: I beam swap
