Thermostat Change?
Thermostat Change?
Since my radiator has developed a leak, I removed it this evening and will be taking it to my local radiator shop for a hopefully reasonable cost repair. Although my exisiting thermostat has been working fine on my 223 I-6, I was wondering since I have the coolant drained and hoses removed if I should go ahead and swap it out for a new one? I try to live by "if it ain't broke, don't fix it" but would still like feedback. Thanks. Steve
Update: Well it looks like I should have changed it out. Installed the radiator, added fresh coolant, water and with the radiator cap off, fired her up and watched to see if I needed to add water after the T-Stat opens; it didn't happen for my mech gauge kept climbing and I shut her down when it reached 200. If the stat was working, it always has opened at 180 and the temp drops back down to 160. I'm still going to test the stat I removed plus the new one I'll be installing. Odd how it decided to apparently fail that is unless I did something wrong but don't know what I could have done wrong.
Hello Ross. The stat that failed was the one that came with the truck. I already had a Stant 160 stat that I got from Napa that I carried as a spare. When I placed them in the pan for ops check, the Stant opened around 165 and the faulty stat finally decided to open after the water was boiling hard. It used to open around 180. Technically it still works but it seems to take a whole more heat in the water for it to open and I'd rather not keep using that one.
Yep, toss it in the trash. 160 may be OK in the summer, but 180 is usually a better all around stat.
One more question; for reinstallation on the 223 I6, my shop manual does not specify which order if the gasket is installed first on the block followed by the stat prior to bolting up the housing elbow. Does it matter? It does specify this for V8s. Also, what type od adhesive can be used for the gasket? Silocone or RTV ok? Thanks.
