Turn Signal Switch Repair - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Log In
Old 07-14-2015, 01:46 PM
Dasher400's Avatar
Dasher400 Dasher400 is offline
Dasher400 is gaining momentum as a positive member of FTE.Dasher400 is gaining momentum as a positive member of FTE.
Click the image to open in full size.
Turn Signal Switch Replacement ’79 Ranger, Auto, Tilt Wheel,with Cruise Control
Not sure if anyone has done a walkthrough on this yet or not. I was doing mine last night so I though I do a write up.
The top locking tab was broke off my switch so I ordered another for cheap. It was like $8 shipping included and it took me all of about an hour to complete.
Step 1.
Remove 2 phillips head screws from back of either side of steering wheel to remove the horn/cruise pad. The pad pulls straight out and allows you to easily access the horn and cruise wires if you have them, they just pull out with your fingers. Remove the nut from the steering shaft with a 13/16” socket. Next, use a puller to remove the steering wheel from the splined shaft. There are 2 threaded bolts holes either side of the shaft, almost like they are there for a purpose . Don’t beat on or pry it off. You will fail miserably and be out a more than a blinker switch.
__________________
1976 F250 4x4 360 plow truck
1978 F250 4X4 4spd 400
1979 F150 Ranger 4x4 Supercab 400 Shortbox
2000 Excursion Limited V10
"Well, I've been to one world fair, a picnic, and a rodeo, and that's the stupidest thing I ever heard come over a set of earphones."
Old 07-14-2015, 01:47 PM
Dasher400's Avatar
Step 2.
This is what you should see now:
Next, remove the turn signal handle (just screws out) and the 2 phillips head screws above and below the steering shaft. DO NOT remove the screw on the switch rocker yet, it will make your life much easier if you till the next step to do that.
__________________
Old 07-14-2015, 01:51 PM
Dasher400's Avatar
Step 3.
At the bottom of the column housing, there is a cover that screws to the dash. It is held in place with 4 screws, 2 you can see from the driver’s seat and to go up into the bottom of the dash. Remove all 4 for access to the wire bundle.
__________________
Old 07-14-2015, 01:52 PM
Dasher400's Avatar
Step 4.
Now you can pull the turn signal switch assembly out the top by pushing the wire bundle up from the bottom and gently lifting the hazards switch. Should be able to clear the steering shaft at the top to allow easy access to for the next step.
__________________
Old 07-14-2015, 01:56 PM
Dasher400's Avatar
Step 5.
This step is optional but I did it to gain access to the tilt column so I could clean it up and tighten up the tilt pins. With the switch assembly out of the way to the left, you can now see the 4 phillips screws that hold the tilt collar in place. Remove the screws and pull the collar up while feeding the switch assembly.
__________________
Old 07-14-2015, 01:57 PM
Dasher400's Avatar
Step 6.
Now you can remove the screw (the one in the middle of the switchrocker) I told you to wait on before.The reason for the wait was so the signal handle base would come out with the signal switch assembly.
With the screw securing the rocker removed, cut the 2 wires as clothes to the rocker as possible (that way you have some room for error down the road). Pull the 2 wires through the back of the assembly make sure to keep track of which one go where or left will be right and vice versa.
__________________
Old 07-14-2015, 01:58 PM
Dasher400's Avatar
__________________
Old 07-14-2015, 02:00 PM
Dasher400's Avatar
Step 7.
After cleaning up the area behind the rocker (careful not to lose those 2 metal strips as indicated) it’s time for reassembly. Place the signal handle base through the back of the assembly, then put the new rocker in place on the front and secure it with the screw we waited to remove. Run the wires from the new rocker through the hole, below the screw, out the back of the assembly.
__________________
Old 07-14-2015, 02:02 PM
Dasher400's Avatar
Step 8.
Splice the wires as appropriate.The kit I bought came with butt connectors so I just used those. I would recommend soldering and heat wrapping. Secure the wires in the bundle on the backside of the assembly.
__________________
Old 07-14-2015, 02:03 PM
Dasher400's Avatar
Step 9.
Now we are ready to test it out. You don’t have to put it all together for a test, just put the assembly in place (make sure the backside of the signal handle base fits securely into its hole, a little dab of grease will keep it operating smoothly too).Secure the entire assembly with the 2 phillips heads screws above and below the steering shaft and try it out. If all is good, take those 2 screws back out, slide the tilt collar back on and reassemble everything.
With any luck, you should be crackin a beer in celebration in about an hour!
__________________
Old 07-16-2015, 12:27 PM
Tank77's Avatar
Tank77 Tank77 is offline
Tank77 is starting off with a positive reputation.
Thanks for taking the time to post this.. I may be going down this road soon..
__________________
1976 Highboy
390
4 speed
37" Goodyear MT
Old 07-16-2015, 06:34 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to beholdmikeo0o0o0 is a splendid one to behold
Quote:
X2. Thanks.
You went into a lot of detail and pictures. This will help a lot of people.
Reps sent.
Old 07-26-2015, 04:14 PM
bkohne1's Avatar
bkohne1 bkohne1 is offline
bkohne1 is starting off with a positive reputation.
My switch rocker is riveted on.?.. No screw in mine. Do I need to buy the entire replacement turn signal assembly?
Old 07-26-2015, 04:31 PM
Dasher400's Avatar
Quote:
Is it a rivet or a clip that snaps over? With a new switch assembly running $60 to $100 you can't go wrong trying to either drill out the rivet and replace it with a screw or snap it back in. Picture?
__________________
Old 07-27-2015, 08:27 AM
bkohne1's Avatar
Quote:
It looks like someone already replaced my stock one with a whole new switch assembly. The cam is riveted on and there is a bundle of splices under the dash. Looks like I will need to replace the entire assembly.
Similar Threads
79 Ford truck instrument harness wiring guide John Rowe 1973 - 1979 F-100 & Larger F-Series Trucks 13 07-23-2014 11:05 PM
How to make your own glow plug wiring harness rosesrfree4u Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-12-2014 12:24 AM
All was good, until I noticed,, (while pulling a 1965 M35 Massey the Tractor weighs 6,017 lbs with all the ballast… probably less...">Transmission No Shift into High dbradicich 1999 - 2003 7.3L Power Stroke Diesel 32 04-29-2014 07:21 AM
My Pace Edwards “Switchblade” Review/Install gaselectjoe 2009 - 2014 F150 5 03-03-2014 04:55 AM
Rebuild Your Own Transmission For Less Than $500! With Pictures! Psygnosis Clutch, Transmission, Differential, Axle & Transfer Case 8 12-17-2012 08:57 AM
Tags
column, rocker, signal, steering, switch, tilt, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
