carb that works with 302/AOD
I'm at the point where I am going outside and cut my truck into little pieces for scrap. If my wife talks me down from that I will need to find a carburetor that will work with a 302/AOD combination. I have a Street Demon carb on another car that I like. The instructions say it works with virtually any combo BUT a Ford AOD. Go figure! It's only because I have seen the miracles you have performed on trucks presumably worse than mine that this truck isn't already an outdoor bench, a bed, or a coffee table. Thanks for any help you can provide.
Edelbrock carbs work with the AOD if used with a Lokar TV cable.
Intake Manifolds - Ford - 289/302/351W - Performer RPM Series - Edelbrock, LLC.
I guess I am missing something...what does the carb have to do with the AOD transmission? As Wayne suggests, the Lokar products work well to actuate the throttle valve (TV) but even that can be screwed up if not installed correctly. There are lots of videos on YouTube that will walk you through the process of hooking up the TV cable and making the proper adjustments...check them out and I think that your dilemma will become a bit less daunting. Good luck...
Isnt the street demon based off the Holley design? I would think there would be a geometry corrector sold for the AOD, I know they sell them for the 200r4 and 700r4.
Found this
https://www.ford-trucks.com/forums/1...th-an-aod.html
Found this
The following users liked this post:
I'm glad they were able to help you. All they could tell me was that their kit and the AOD will not work with my stock carb on the flathead. They did suggest I contact a carb company for the solution, but so far no luck.
ssanto
07-28-2006 08:33 AM
oldfordtrucksrule
04-14-2005 09:20 AM
