A quick and easy oil filter question... - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Log In
2004 - 2008 F150 2004, 2005, 2006, 2007 and 2008 Ford F150's with 5.4 V8, 4.6 V8 or 4.2 V6 engine
Old 07-14-2015, 11:34 AM
Zzolo1225 Zzolo1225 is offline
Zzolo1225 is starting off with a positive reputation.
Hey guys, I just bough an 04 f150 fx4 off my step dad. He had the motor swapped last year as a bad mechanic ruined the other one. So he got a "long block" installed which last i checked just means he got a block and heads. This is not a specific motor type. I want to make sure that when I go to get an oil filter in getting one for the 5.4 V8. Am i correct? And does the oil filter on this motor get used on their other V8s? I just want to make sure if it has a different motor for some weird reason the filters don't really change or something. Thanks!
Old 07-14-2015, 12:11 PM
07F150Lariat5.4's Avatar
07F150Lariat5.4 07F150Lariat5.4 is online now
07F150Lariat5.4 is gaining momentum as a positive member of FTE.
Yes, 5.4 engines all use the same oil filters, as well as the 4.6.
__________________
2007 Ford F-150 2wd Lariat SuperCab 5.4L
Mods: Magnaflow SI/DO exhaust & aFe Stage 2 CAI
Old 07-14-2015, 10:38 PM
air1jpg's Avatar
air1jpg air1jpg is offline
air1jpg is starting off with a positive reputation.
I would stick with the Motorcraft oil filter as it has an anti-drain valve in it to make sure your head have oil at all times. Not all filters have this valve that fit a 5.4l engine.
__________________
________________
Jon
2006 Black F-150 FX4 Off Road SCrew 5.4L
6.5' StepSide Box, 20" Cooper AT3 Tires, 3.73LS, Backup Camera,
Luxury Package, Cobra CB Radio, Tinted Windows
Electric Trailer Brake Controler, Hard Toneu Cover from Undercover(http://www.undercoverinfo.com)
Old 07-15-2015, 08:54 AM
Is there any engine that could have gone in to replace the 5.4? Step dad swears they put a larger motor in it than the 5.4 triton. So if there is anything bigger they could have put in what would my options be? Is there somewhere I can look to get an engine num?
Old 07-15-2015, 09:16 AM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is starting off with a positive reputation.
Anything other than a direct replacement would have been very expensive because of the computers, electronics, etc. that would all have to be changed, among many other concerns. Highly doubtful the engine type was changed.
__________________
2007 F-150 V6 5-Speed Manual
Old 07-15-2015, 03:00 PM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT IROCKWITHDIRT is offline
IROCKWITHDIRT is starting off with a positive reputation.
+1 for using a motorcraft filter.
__________________
99 F250 SCLB 4X4 V10
93 F150 RCLB 2WD 5.0
71 Chevelle SS 402/4sp conv.
65 Chevelle 406/th350 wagon
73 Trans Am 1/4 mile car
70 Triumph 650/5sp chopper
Similar Threads
Oil Leak @ Oil Cooler Adaptor Fixed! HearseDriver Modular V10 (6.8l) 2 05-27-2015 11:42 PM
What causes noisy lifters? Tappers? blueeyedfordguy 1997 - 2003 F150 1 02-23-2014 11:11 AM
wife looking for help! rpau5588 6.0L Power Stroke Diesel 45 01-19-2014 11:29 AM
Potential Dip Stick Issue? JWA Oil & Lubrication 1 12-02-2013 03:09 PM
Dip Stick Issue? JWA General Automotive Discussion 2 12-02-2013 06:52 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
