S wire on solenoid
S wire on solenoid
I've got to be missing something very obvious here but I can't seem to find it. I looked through all the recent starter threads I could find but nothing hits me yet.
My S wire has constant 12v when key is on. I've swapped switches and get the same results. I have two more switches that I'm gonna try but I'm not entirely convinced that's the issue. what am I not thinking of? Not all of my wiring is reconnected but all of the starter circuit should be. Thoughts?
Are you sure you have your solinoid wired correctly? Only one wire should be going to the S terminal and it should be dead until you turn the key all the way to start. i would trace that wire and make sure nobody connected something else to it. Start under the dash. Previous owners love to mess up wiring under the dash.
I'm rewiring the whole truck, so that's my issue. lol
I know it's the s wire, and I hooked a test light to it to confirm it's getting constant juice. When I turn the key off, it shuts off, but is on during run and crank.
You may be the winner ron, this wiring is probably out of one of my auto trucks, so that could very well be part of the problem. But I would think if the NSS was not hooked up, I shouldn't get any juice. I'll check it out and come back.
Yes, red/blue tracer is "S" terminal and the brown is "I" terminal on the starter relay. The reason you have 12v on the brown is that it is the full 12v bypass to the ignition coil that is fed from the starter relay during crank. It has 12v on it now because it is in parallel with the lead that feeds the coil thru the ballast wire and you are not running the engine. The full 12v comes thru the starter relay during crank only. Hope this isn't too confusing.
Sounds like others have you on the right track regarding the I and S wires being swapped - brown should be I and red/blue should be S, as ronspolv said. I'll second co425's suggestion of the NSS being the problem. Should be a 4-wire connector though: two red/blue (connected in park/neutral for starting), and two black (w/ a tracer color I can't recall, maybe red) ones for the reverse lights, when in reverse.
on
What year is this? I'm guessing '78 that's in the avatar...
There should be no voltage if the NSS switch isn't hooked up. Perhaps it's getting mixed up with the Backup Light circuit? Pull Fuse 11 and see if there is still voltage to the Red/Blue wire...
Check Connector C-1015 Which is what the NSS plugs into for autos. Here's a photo of my '78, which is a manual and has a jumper wire for the Starter Solenoid/Relay 'S' Terminal.
Hope this helps!
