Help please! Backfired so hard it blew out my muffler!!
Hi guys!
I apologize if this post is repetitive, but me and this "search" function don't get along so well.
I've got a 77 F150 4x4. 351; 2 barrel carb; 4 speed manual tranny.
I drive it on a fairly regular basis. But it has sat for the last month. The other day I jumped in to take it for a spin. It cranked and cranked and cranked like there was no fuel. I pumped and pumped and pumped til it started. It has done it like twice again. But usually starts normally. This morning, I took it to work. Been driving for about 10 minutes, and it died. I'm coasting in gear for just a few seconds and it fires back up and backfires very loud out the exhaust. Almost to work, I cruise on in.
Coming home, same thing. About 10 minutes into the trip, it does the same thing. This time it blows out my muffler. Now I sound like i"m driving an old farm truck. Then it did it to me one more time, cept I stepped on the clutch and pulled over. Then it cranked and it cranked and it cranked til it fired back up and I went home.
What do you think? Fuel or electric? I can fix stuff, but not so great at diagnosing. Obviously had SOME fuel to backfire that hard, right? Am I losing spark for a few seconds then gaining it back again?
I'd appreciate some thoughts if you all have any. Holler back if I can give more explanation. Thanks!!
Scott
Scott
Something is shutting off the ignition. If I had to take a guess, I'd say it is the pickup coil in the distributor, ignition coil, or the control box for the ignition on the inner fender. There are ways to test the pickup coil, tests have to be done when the engine won't start. Check all the connectors at the ignition switch, distributor, starter solenoid, & ignition module. Make sure they are clean & tight.
The engine keeps spinning, pulling gas & air into the cylinders, then pumping it into the exhaust. When it starts firing again, the fuel air mixture ignites & explodes.
Back in my younger days, we used to do muffler explosions all the time. Cruise along at 35 or so, turn the key off one click for a few seconds, turn it back on. BOOM!!!! Great fun when a dog was chasing you! I had a 76 F150 4WD with a single 3" exhaust pipe straight out the back. Late one night some dullard was tailgating me. I lit off a big muffler explosion, it looked like a ball of fire rolled over his hood. He backed off right quick!! Glasspacks were the best, they were very hard to blow apart. Rusty mufflers usually came apart in a couple of explosions. AHHHH, the fun of vehicle abuse!
I know you say that you cannot diagnose a problem, but ummm.... you are going to have to in this case.
At the very least you'll need to run through a few systems to figure out where the fault lays.
good luck!
Keep in mind, when it's required to "crank and crank and crank" this will smoke the battery, and hard. They are not designed for that and will be ruined quickly if not charged up.
The alternator will be tasked to charge but they are not designed for that, and can be ruined by a defective battery. Especially, starters are not designed for marathon crank fests. It will get smoking hot, may not fail right now, but it will fail fairly quickly.
Not trying to beat up on you, but this is a textbook example of how a tiny fault causing a no-start condition in turn affects other major sections or components and can get pretty expensive and extensive if not remedied right away.
^ This is my first guess. If the mounting bracket is a little loose and it sometimes bounces out of position, it would kill the ignition, but could fall back into a good enough position to run after enough cranking sometimes. If when you're cranking and it's not starting, it fires once right when you turn the ignition off, that would be a confirming symptom of this.
my brothers '63 chevy pickup would unload the condenser every time he shut the key off and the engine stopped rotating, blew his mufflers off multiple times and also made it hard for him to sneak home after curfew.
Not the you have a points or a condenser but figured I would bring it up...same principle.
ha ha....ok. I do have lots of tools. Just, my electrical skills are weak....... I will have to study on how to use the dang thing.....
