Approximate cost of having a new timing chain/gear installed.
Old 07-12-2015, 02:13 PM
NICKSAN's Avatar
NICKSAN
NICKSAN is offline
On my 94 5.8 club wagon?
I have a pretty bad rear seal leak that I was quoted around $1000 to fix because they have to drop the trans.
Thanks.
Old 07-12-2015, 02:27 PM
Hank85713's Avatar
Hank85713
Hank85713 is online now
depends on your location. The guy I use charges a basic $300 plus parts (which I provide) and so it would be about 6-700$ for labor and parts. You go to a dealer shop and you can expect 2-3 times the cost. Find a good indy shop with recommendations from others and see what they want. I paid $700 for rear main install, but it was not leaking, and he put the clutch, slave flywheel in because it all had to be pulled anyhow. The next was a leaking pan gasket so He pulled the engine up enough to get pan off. I got a new oil pump while he was in there again no cost to install since he had pan off. Just need to see who does quality work and how much they will charge ya.
Old 07-12-2015, 07:41 PM
NICKSAN's Avatar
NICKSAN
NICKSAN is offline
Im in So. Cal. Im gonna call around and see what I can get it done for. Thanks.
jeepsterjc
09-27-2015 07:54 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
01-06-2015 01:51 AM
ExitLeft
05-07-2013 05:24 PM
RyanJake
02-22-2007 10:33 AM
shel 67
Aerostar
05-15-2004 12:40 PM
Quick Reply: Approximate cost of having a new timing chain/gear installed.
