My rear end bit the dust... - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Log In
Old 07-11-2015, 09:00 PM
frank5079's Avatar
frank5079 frank5079 is offline
frank5079 is starting off with a positive reputation.
On my way in to work this morning, I noticed a louder than normal whine coming from the rear end of my truck('95 F150 XLT). Working at a dealership, I had one of the techs I work with raise it on the lift to have a look see. Well his prognosis was grim and he showed me where the rear end had hemorrhaged gear oil all over the place. His advice to me was to find a replacement rear end because mine is dead.
After punching in my VIN on the VIN decoder elsewhere on this forum, I found out that I have an 8.8 inch rear end with a 2.73 rear axle ratio.
Since I have to replace the rear end, can't I just use a good old 9 inch rear with a Traction Loc differential? What do you guys think?
Old 07-11-2015, 09:05 PM
Toplait's Avatar
Toplait Toplait is offline
Toplait is starting off with a positive reputation.
Have you inspected the parts inside? Those 8.8's are pretty tough rear ends...Just replace a few bearings and seals and your usually good to go.
Old 07-11-2015, 09:22 PM
frank5079's Avatar
Quote:
If I went that route, could I yank out the gears and replace it with this?
Click the image to open in full size.
Old 07-11-2015, 10:34 PM
Toplait's Avatar
IF it is for a 8.8" and it matches your Axle splines then yes. I think your axles are 31 Splines. I could be wrong. You would have to check.
Although, You would need to have it professionally installed.
Old 07-12-2015, 01:06 AM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
No place for the VSS, so no speedometer and rough shifting along with codes out the wazoo if you have a E4OD transmission...
__________________
No matter how carefully you choose your words, they'll always end up being twisted by others!
1993 Thunderbird LX 3.8L AOD.
1997 Explorer XLT 4X2 4.0L SOHC 5R55E
1997 F-250 HD Extended cab, long bed, 5.8L, E4OD.
Old 07-12-2015, 04:01 AM
frank5079's Avatar
Quote:
I have a 5 speed manual transmission...
It is for an "8.8" rear end. I did this to the rear end of my Chevy Monza, several years ago, but it had "C" clips which held the axles to the differential gears. Pull them and the axles slide out and you just pop the LSD unit in place, slide the axles back in, reinstall the "C" clips, and the rear cover, and refill with LSD specific gear oil.
Old 07-23-2015, 06:51 PM
frank5079's Avatar
If I swap out my rear axle housing with one from a '95 F250, will the 5 lug axles from my rear end swap in place of the 8 lug axles of the '95 F250 rear??
__________________
Being disintegrated makes me very, very angry!!
Old 07-23-2015, 07:13 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to beholdrla2005 is a splendid one to behold
No...the F250 uses a Sterling 10.25" rear axle. Completely different animal.
__________________
2013 Ford Taurus Limited 3.5L
2006 Ford Mustang GT 5-speed 3v 4.6L
rla2005@yahoo.com
Randy A | Central Illinois
Old 07-23-2015, 07:39 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Now would be the time to swap in some sensible gears.. like 3.55. If you want a little tidier swap go find a complete 3.55LS axle at the junkyard, have it gone through and bolt that in under the truck.
__________________
Paul (Conan) O'Brien
2006 E250 4.6L 4R75w 4.10, 2004 Ranger 3.0L 5-sp X-cab 4.10, 1994 Ranger 3.0L 5-sp x-cab 3.45, 2004 Subaru Legacy 2.5L 5-spd
1996 Kawasaki ZX11D, 2002 Honda VFR800,
Old 07-24-2015, 12:09 AM
twigsV10's Avatar
twigsV10 twigsV10 is offline
twigsV10 has a very good reputation on FTE.twigsV10 has a very good reputation on FTE.twigsV10 has a very good reputation on FTE.
If the differential was run without or very low oil the front pinion bearings are likely toasted, replacing the spider gear assembly with a LS won't fix this.
Unless you are very good at setting gears (it's more complicated and expensive to have done then you would think) I would recommend finding a used axle with a 3.55 or 3.73 gear ratio and then think about changing the spider gear assembly.
__________________
89 ranger 2.9 reg cab short box 220,000 I just won't let it die
94 f150 (sold)..... that was dumb......
99 mustang GT 35 anniversary
06 f350 v10 reg cab srw
05 Expedition 5.4
Andy
Old 07-24-2015, 06:40 AM
My4Fordtrucks My4Fordtrucks is offline
My4Fordtrucks is starting off with a positive reputation.
As long as it was only the bearings and the the housing is still undamaged, replace the bearings and get back on the road. If you want to add a LS that reuses the same carrier that is up to your wallet. If a different carrier is needed it would have to be set up correctly.
You could get another 8.8 from the junkyard with a better ratio from a Bronco or F150. As stated you need the speed sensor in the rear diff for the speedometer and ABS to work.
Similar Threads
VIN Decode/ Number Dummy HELP! thorswhisper 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 05-04-2015 12:02 AM
Rear end Question 1999stroke 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-29-2014 07:23 AM
Explorer 8.8 Rear End dferrell5 1948 - 1956 F1, F100 & Larger F-Series Trucks 30 01-25-2014 01:26 PM
rear end fluid change RobertJohn 1999 - 2003 7.3L Power Stroke Diesel 9 11-21-2010 10:35 AM
Correct tool for removing sterling 10.25 rear end drums fepowerguy8 1987 - 1996 F150 & Larger F-Series Trucks 13 10-08-2010 07:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
