5.8l is out. Need some advice please
So my donor 5.8 is out. My headers seem to not have the ports for the hoses that go to the air pump...... do I need these hoses and weird plastic looking thingy and air pump connected for a smooth daily driver? Can I delete these? If so, does anyone know the belt number I would need for deleting the air pump as I am not fond of the idea of having it just mounted there for the ride......The headers have the hook up for the egr and I will run that.
I have pictures but can't see how to post ... in case you want to see.
Thanks in advance
Thanks in advance
No you do not need any of the Smog pump stuff. Delete all that and run a shorter belt. Plug the holes in the back of the heads. Cap off the vacuum lines.
Also, if those are the Longtube stainless steel headers off ebay and if you do not have them bolted on yet. You may want to try cause mine did not fit.
Be sure to use Anti-Seize on the EGR pipe threads.
Fordman2822
17
03-31-2018 02:07 AM
fishman1964
01-15-2007 09:49 PM
