No brake lights on a 1967 f100 camper special
Well, I tried everything I could figure to do. I have the wiring diagram( maybe not reading it right?), have juice at the brake pedal switch, all other functions work in the tal light assembly, but no brake lights. Checked underneath with a test light and have some of the wires showing current. I hate wiring ,please help.
I have tail lights ( lights that operate when headlights are turned on) turn signals and backup lights. I have hot at the brake light switch and at the other side when the pedal is depressed. I have been using this diagram http://automotivewiringdiagrams.net/...ng-diagram.jpg but am not familiar with the device between M and N. If I am correct in reading this, the brake light is powered by 383 red/white stripe to 284 red out to the brake light switch. 810 red w/ black stripe is the wire that comes off from the brake light switch when closed and goes into a connector. I can follow the wire to the switch, but it goes into a taped harness from the brake light switch and I lose track. Any body been to this point and can give me a little direction?
There are 3 wires going to the rear of the truck down the drivers side frame rail. 1 wire is for tail lights, the other 2 are for brake and shared with turn signals.
If you have turn signals (both sides) then the brake lights should work as they share the same wire.
Have you done any recent work to the wiring at the front of the truck? The steering wheel area?
You are sure with the ign. switch on and the pedal depressed there is power on the second wire at the brake light switch (power out).
Something is stopping brake light power. And if the turn signals are indeed blinking on the rear, it's at the front of the truck.
John
John
Ughh, bunch of spaghetti. Do you know the location of the components circled in red? wiring diagram by gearhed1971 | Ford-Trucks.com
What you have circled is the turn signal switch, right under the steering wheel. The wire that leaves the brake light switch runs through the trun signal switch that is way I ask if they worked. If power is going through the brake light switch and the turn signals are working it has to be the turn signal switch or the wire between it and the brake switch
