B&W 1356 Transfer Case Corrosion
I have been working on getting the transmission ready to swap out of the 95 F350 and into my 90 F350. I was looking at the transfer case and I noticed some alarming pitting corrosion on the aluminum case and I wanted to share it with all of you and ask for your opinions. I really don't like the way the aluminum is corroding away like it is and I really don't want to have problems in the middle of winter. Should I not use this case? I do have another case ready to go.
on
as far as i know the cases are all aluminum.
some f350's came with t-cases with an optional PTO output.those ones had half a case which was magnesium.no welding was done Brad.the half which housed the pto output was magnesium.
nothing needs to be done here.this t-case will burn up and fail.........long,long,long before she'll corrode away.by like several decades lol.
Here is an update... My 1990 F350 project truck for Wisconsin winter use, has its transmission and t-case removed. It was a minor challenge doing it on my own, but it is out. Now I have to get the ZF5 out of the 95 (pictured above) so I can swap it in. BTW, now I know why the clutch slipped so badly! It was completely wore, even the tops of the bolts that hold the flywheel on were damaged by the springs riding over it. Some of the pads are completely off the disk, and the flywheel looks like a mirror! I am surprised the truck even moved!
