Truck died on me, need a little help
So I'm down to one tank, as the rear is pulled to install the 38gal F26E tank. And it's been running rough on the front tank, currently its sitting on the side of the road waiting on a tow truck. Tank is 60% full I went to turn onto the freeway and the truck fell on its face, no power and it soon died. I had this issue a while back but after changing the oil, and fuel filter u haven't had any issues. Oil is fine, fuel filter is fine, could be a CPS, I have a spare one in the glove box I can try. When I try to start it sounds like it wants to turn over but never does. Just looking for ideas. So crank and no start.
***edit*** replaced the CPS and still the same symptoms, could be two bad CPS's but I'm ruling it out. Next would be fuel pump I'm guessing. possibly the HPOP???? im really needing some help here guys.
OK the tach moved but i dont think it ever moved above 250-300, CPS is a Motorcraft, I get a WTS light, didnt notice any smoke, and the oil pressure gauge does move when i crank. I get an engine temp light and a fuel filter light by the WTS light, I havent had a chance to dig into the truck as i didnt get home until 8 and had to be at work at 4. I did check the fuel filter and didnt see anything that struck me as unusual, it was clean.
Lastly im in Laveen Az, which is basically south west Phoenix. and Madpogue ill be in madison next month for a class at the university if you wanna grab a beer or something.
Have you been getting that rain where your at? Maybe you've got water in the IDM as funny as that sounds being from AZ.
More likely is the fuel pump. You need bare minimum 20 psi cranking to start.
Turn the key on without turning the motor over for 2 minutes. The CEL should come on. This way we can verify that your CEL bulb is not blown.
havent had much rain here, a bit humid but rain no so much. I will hopefully get a chance to check fuel pressure tomorrow, today in my birthday and im not canceling my plans to deal with the truck today. Today i get to deal with issues at the dairy, seems like our agitator goes out once a week and the dairy manager is... well... lazy...
