Anti-rattle/Window Seal Kit Install Question
How do you install the window seal kit on a 1968 f100? I have the LMC kit, part number 49-7115. I removed the armrest, window handle, door handle and the metal access panel but stopped there. It looks like I have to drop the window, but I'm not to sure how to do that. Any tips or suggestions will be appreciated.
Thanks.
Thanks.
Thanks.
Thanks.
on
And after all that work on the wing seal installation you'll find that they don't fit worth a damn.
The die they use to make these must have been made from an old shrunken up wind wing seal. That's how well they fit. Very disappointing as they still leak water and have air gaps where it should be wider to fit the door edge better. And I got mine from DC
LMC has the worse rubber products that after a few yrs they crack from the ozone. I've had to replace ALL the LMC window & cab mounts even the gas cab filler neck donut. Any one who uses LMC rubber You'll see!
Orich
on
Gee wish mine just fit into a slot, not like in the video but no they had to be glued into place as this was even DC instructions in the back of their older catalogs.
As, I now have 2013 book and it don't say any thing about gluing them in now. Well maybe the seal is made better today.
This was how it was done before and had to leave it clamped over night.
I finished up the vent window seals tonight. The ones from Carpenter fit perfectly! A little dish soap and they snapped right into place. Contrary to the DC catalog, they included rivets. Once you seperate the glass run from the vent window channel you just drill out the rivets. I took the time to sand and paint the vent window frame and glass frame. I used a piece of bar stock in my vise as an anvil, and peened the new rivets in place using a center punch and drift punch. Tomorrow I'll put them back in the doors.
They cover the same area as the ones I took out. They are quit no wind noise with them. As for as leaking water, you'll probably laugh but nether truck has ever been in the rain, and I just use detailer and microfiber cloths to clean them. That's sure not the case with my Flareside though. LOL
After installing all the door glass, I have to say I'm a little disappointed. While the vent window seals fit the windows just fine, the passenger side seal does leave a small gap at the bottom where they meet the outside of the door. This will indeed leak water. I'm gonna try some black sealant to fill the gap. The driver side is better. It seems like the window opening in the passenger door is wider than the driver side.
Getting all that installed in the door is a monkey puzzle! But I got them both done!
on
You maybe right about it being wider. I never measure it. My Right side has a larger gap. My truck was built in San Jose Ca. wonder if that has anything to do with it.
I'll measure my in a day or so just for shxts & Giggles.
I have seen better fitting wing seals on a few trucks out at the PnP= JY
I know the disappointment you feel. And I had to glue them in.
Orich
Orich
