P0193 code
P0193 code
I went to the dealer with a P0193 and he said to me that the left fuel rail needed to be remplace because it have a little welded hole that block some fuel line when i need throttle !! So i remplace the fuel rail and the truck be OK for two days after this it begin to stall in 1 and 2 with the engine light on.........
I disconnect all the connector from the PCM and disconnect battery to reset the trouble code. It runs number one, two days but the P0193 reappear with the battery light on....
Someone had the same problem and know how to repair the trouble? I thing it's a wire somewhere was ground or broken but I don't know where the Frp is on the engine
Thanks!
PGM
Thanks!
PGM
see if this obdii helps...this is for 2011...you didn't say what year your truck
http://www.motorcraftservice.com/vdi...DOBDSM1101.pdf
if another year, go here and select
https://www.motorcraftservice.com/vd...&menuIndex1=10
CPTMidnight
6.7L Power Stroke Diesel
18
05-16-2019 05:17 AM
tome
01-20-2004 08:35 PM
