Time sensitive help needed/engine install
Tonight I am in final preparation to put a 302 in my 56'. I have a friend coming over first thing in the morning so I don't have time to search this topic fully. I believe the popular opinion is to offset the motor about an inch toward the passenger side for exhaust clearance with the steering. My friend says he has never done this and it's safe to say he is not on board. I rely on him a lot and hate to go against his opinions unless I have the collective experience of you guys to support what I think should be done. Could you please refresh my memory and confirm or deny the one inch theory. THANKS! I'm back outside to continue preparation. Wish me luck.
Hey Matt,
We have a 351W in our '50 F1 - Yes we moved the engine over an inch and a bit over toward the passenger side. You'll see when it comes time to connect your steering - it's tight on the driver's side. It's also tight up by the radiator - make sure you have enough room up front as well.
Good luck over there in Bakersfield. (1) vote for the inch.
Ben in Austin
(San Francisco this week)
Ben in Austin
I would advise against running anything crooked, crank center line should run parallel with the pinion, not angled at it. Offsetting to the side is fine as long as the engine and trans are moved over as a unit. As already mentioned you want to have your steering, exhaust, and radiator placement planned out now or chances are good at having fitment problems later.
Here you go, John has put it together for you!
http://jniolon.classicpickup.com/dri...nephasing.html
THANKS
Thanks to all who responded to my desperate call for quick information. The engine is in and offset probably 3/4" toward passenger side. That's the best we could do. Sure is nice to look at the truck without an engine puller in front of it in addition to misc. jacks and wood spacers under it. Going to enjoy the victory for a day or so. Stand by for the next batch of questions when I start back up..........THanks
mustangmike6996
02-11-2015 08:44 AM
special 55
26
03-01-2011 01:09 AM
irondragon79
10-08-2002 08:24 PM
