My "70 long bed has a GVW of 4500(F103 code). I noticed one less than that at 4200(F101). Is 4500 the lightest for a long bed, is the F103 a short bed GVW?
4500 is the GVWR. Not how much it weighs. If you have a stock truck with nothing added, it probably weighs between 3600-3800lbs depending. Go to a local scale and find out.
Gassed up with me in it, my truck weighs 4200lbs. But I have a loaded toolbox full of heavy stuff mounted in the bed, I run bigger heavier tired than stock, and I have a heavier transmission than what was stock.
Huh, interesting. I guess the 4800 and 5,000 ratings were possibly for 4x4, or maybe the heavy duty special trucks. 4500 is the only one I've seen on 2wd longbeds
