Banjo Brake Fitting Crush Washer
1955 F600
Rear brake line attach to wheel cyclinder with a banjo fitting, unable to find the thin crush washer/gasket for the bolt. Anyone have a source for them?
May try to do away with them and attach line directly to wheel cyclinder if I can find a fitting
Thanks Dennis
Thanks Dennis
Ford Master Cylinder Fitting Copper Washer - 91A-2152 - C&G Ford Parts
Used in several places on the brake system
Keep in mind that this is a F600 with dual wheel cylinders
The block that the line hooks too and bolt goes thru. The bolt holes are slightly indented for the crush washers to conform to the shape when it is tightened. I'll get to town. To a big truck parts place and see what they can come up with. Also takes 2 different sizes per bolt. The banjo bolt is like a shoulder bolt
I looked again, there are two different washers used, the inner one is likely what you are looking for, the 91A-2149. But a search on that shows many people selling them, and they are not a crush washer.
Ford - Ford Pickup Truck Brake Line Copper Washer - .453 ID | 91A-2149 - Macs Auto Parts
acl9865
07-05-2018 09:38 AM
Connecticut Calvin
07-15-2015 03:54 PM
vfrf2
05-16-2014 08:33 PM
