Checking out a used 6.8
So I bought this 99 f250 6.8 auto 4x4 about a year ago. I bought it with a blown engine (rod punched hole in the block) as a project truck, and have finally got a replacement engine. The replacement is a 00 6.8 with just under 120K miles on it. I have never been a fan of junkyard motors simply because you have no idea how much life is left in them. Here are my questions
Are there any compatibility issues between a 99 and 00 6.8?
What can I do as part of an inspection to make sure the engine isn't junk? I was planning on getting an oil analysis and pulling the pan to look for loose rods etc...
Are there any upgrades or known problems I should fix while it's out of the truck?
Thanks in advance for your help!
Theres nothing major different you might need to swap a few things from your old motor but not many. I'd do a compression test and slap her in. Oil analysis isn't a bad idea gives you an idea how it was treated. Should be fine though modulars are 300k motors if you take care of them. If v10s break exhaust manifolds bolts like 5.4s do I'd get some new manifolds and bolts in while its out.
Is this something I could download and push to the ecu, or do I need to have someone retune it? I've replaced computers, and read codes but never changed the tune.
Thank you all for the input! Spark plugs are definitely on the list to replace, and after reading some threads on plugs i'm probably just going to go with some champion platinums.. maybe Iridium?? I had also considered some MSD COPs but the budget probably wont allow it anyway.
With 120K on the engine is there anything i could/should do with the injectors while its out(replace/clean/rebuild)
Mike189677 I'm assuming this is what you're talking about?
Since the entire engine is easily accessible very easily now I'd like to do any services that will be a complete knuckle busting pain in the butt once its in.
......but they do have potential 'blow out' issues. Change them and absolutely follow Ford's procedure, including their torque figure.
Velislide
1999 to 2016 Super Duty
28
04-30-2009 07:59 PM
