lift up window/lock on 96 ranger
I would check out the older model convertible motors and hardware. They already have the reversable 12 volt motor and there's so much hardware out there, you could make something up fairly easily. On the older ones also, you can release the switch in any position and thats where the window stays. You'll always have to open it electronically, unless you get lucky and find one with a manual wrench. Once it's down, you can't open it, so you don't have to worry about locking it. Plus, the motors are small enough to fit under the lip above the window. Out of the way! Makes me want to get to work right now! Naw, its 1:30 in the morning!! Happy Friday!!!
