Higher Capacity Fuel Tanks for the OBS
What broke, exactly? The float (the little brass barrel), the arm (L-shaped wire), or the sending unit (variable resistor)? The float just snaps onto the arm, and is replaceable. Gotta be careful where you source it, though. I replaced the front one in our blue '95 just a couple months ago, and it's already failing. I *THINK* I got it from Jegs, but would have to check my receipts before I diss them.
I couldn't say for sure but I can't see why it would. Basically add 7"'s to the bottom of your tank.
In respect to air bags if you have the over spring ones no worries, inboard ones I wouldn't think so. In fact I like my air bags even more especially with the added weight behind the axle.
Running a 4" (or larger diameter) exhaust in stock location with mine I had to trim the passenger side tank tank guard at the forward corner so it wouldn't touch exhaust. Fitment is snug but there was room.
jrc
jrc
#28
I had the resistor break on me, damn think was brittle and broke just opening the case. I epoxied it back in. We'll see if it works, worst case is that my gauge wint work until I'm around 60% left in the tank. Still need to bend up a new float, and I'm trying to figure out what size compression fitting you guys may have used. 3/8 is to big but 1/4 is to small.
I was really wanting to have this done asap but then we had a critical piece of equipment at work break yesterday and my 8-9 hour day turned into a 16 hour day.
